Testing extruder hobbed gear
A project log for Jadoo's All in one
An all in one DIY lab in a box 3d printer, laser cutter Heated Chamber and Exhaust removing enclosure.
eric-jadooEric (Jadoo) 08/21/2014 at 05:030 Comments
The first hobbed gear tested didnt have quite enough grip so i cut another with deeper grooves, that in turn gave better results but marred the filament making jams more likely. Will test it more once the z axis is further along...
