4 port USB hub in a square inch
Gotta have more USB ports
I always thought this chip would be really cool if I could get it to work. This is my first attempt, just happened to be less than a square inch. Hopefully it works!
Hopefully this is a full speed USB hub, so it can be used to chain PCM2906 sound cards without degrading performance. If not, well, it'll still work for slower things.
Board sent off to OSHPark september 1st, all components are in hand. Here we go.
FE1.1S-inch.sch
first test
sch - 388.29 kB - 09/02/2018 at 06:42
Download
FE1.1S-inch.brd
first test
brd - 73.33 kB - 09/02/2018 at 06:42
Download
  • USB hub is live
    mitchell.dokken09/20/2018 at 02:02 0 comments
    It works! Nothing much to the design but some capacitor filtering and a specific resistor value. It takes 5 volts and shows up as a High-speed USB device:
    usb 1-3.2.4: new high-speed USB device number 47 using xhci_hcd
    usb 1-3.2.4: New USB device found, idVendor=1a40, idProduct=0101
    usb 1-3.2.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    usb 1-3.2.4: Product: USB 2.0 Hub
    hub 1-3.2.4:1.0: USB hub found
    hub 1-3.2.4:1.0: 4 ports detected
    So thats cool. I cheaped out on the decoupling capacitors for the crystal, as other designs I'd seen didn't have them. It worked without them, and they're trivial to add.  I could shrink this further by getting more aggressive with the pad layout, using one of those 2.5 x 2mm crystals, and 0603 passives.
View project log
ja.ten.pony wrote 10/04/2023 at 22:32 point
Where did you source the FE1.1S from? I'm, finding it difficult to find in the US.
Miguel wrote 09/24/2022 at 15:11 point
Hi,
What IC is this project based on?
Patrick Hinchey wrote 12/23/2022 at 21:09 point
FE1.1S
Elliot Williams wrote 12/18/2018 at 13:37 point
Awesome!  This kind of project is why I love the square-inch contest.  Simple. well-executed, and done.  Open for anyone to copy.
Thanks!
