The ultimate stompbox. It is not just a stompbox, it is a metronome, a drum machine and more.
hopzbox.fzzNew schematic with OLED modulefzz - 172.23 kB - 10/30/2018 at 19:56 |
I started to use an OLED module instead of the 8x8 matrix. It looks much better :) , and because of the I2C I need less resource and less I/O pin.
The wav-triggeer board was arrived, so here is the first soundcheck :)
First schematics was redesigned, and added another multiplexer/demultiplexer because of the lac of the enough I/O pins.
First parts are arrived and started to write the first codes for sound detector ad for the 8x8 matrix.
