2.2.2 dev. snapshot: EMIT vector, more general Y=TOS, improved number conversion
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 12/18/2016 at 19:150 Comments
The 2.2.2 snapshot provides some important changes
Here is an example for valid number strings:
DECIMAL
$10 $-10 -$20 20 -20 %1111 -%1111 .S
16 -16 -32 20 -20 15 -15 ok
HEX &16 . 10 ok
Since NUMBER was re-implemented in a mix of STC and assembly the binary size of this snapshot is significantly smaller even if there are more features. I checked the code size again: MINDEV including the new features, and WORDS_EXTRACORE is now 5185 bytes, down from 5320 bytes a week before. Bare-bones CORE is now 4195 bytes, down from 4350.
Maybe the vectored EMIT is also interesting: as I plan to support more board and features like more than two character output devices, I removed the board dependent output for the background task with a more flexible approach: USREMIT now holds the address of the basic character output word for the active task (foreground or background). The default EMIT word for background can be configured in the board's globalconf.inc. The default for W1209 is EMIT7S (7-seg-display). For all other boards it's simply DROP.
