​Bump to v2.2.3: important non-functional changes
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 12/27/2016 at 21:530 Comments
Most of the changes in v2.2.3 are non-functional, but some is nevertheless important:
Did I mention that MINDEV is still below 5000 bytes even if I linked or added 22 words more to the vocabulary than in the last release?
stm8eForth v2.2
words
 RESET RAM NVM LOCKF ULOCKF LOCK ULOCK ADC@ ADC! 2C@ 2C!
BITSR WORDS .S DUMP VARIABLE DOES> CREATE IMMEDIATE :
CALL, ] ; ." $" ABORT" AFT REPEAT WHILE AHEAD ELSE THEN
IF AGAIN UNTIL BEGIN +LOOP LOOP DO NEXT FOR $," LITERAL
COMPILE [COMPILE] C, , ALLOT ' [ \ ( .( ? . U. TYPE U.R
.R CR SPACES SPACE NUF? KEY DECIMAL HEX str #> SIGN #S
# HOLD <# DIGIT PACK$ ERASE FILL CMOVE @EXECUTE PAD
HERE COUNT 2@ 2! +! DEPTH PICK 0= ABS NEGATE NOT 2/ 1-
1+ 2* 2- 2+ */ */MOD M* * UM* / MOD /MOD M/MOD UM/MOD
WITHIN MIN MAX < U< = DNEGATE 2DUP ROT ?DUP FILE HAND BG
TIM -1 1 0 BL OUT '?KEY 'EMIT hld BASE UM+ - 0< OR AND
XOR + OVER SWAP DUP >R R@ 2DROP DROP I R> C! C@ ! @ EXIT
EXECUTE LEAVE EMIT ?KEY hi 'BOOT OUT! TX! ?RX COLD ok
Now I did :-)
As usual, the binary release is on GitHub.
