-Raspberry pi
-wireshark install/ kali install/ aircrack-ng
- camera
- wifi adapter
- backup battery
- case
OVERVIEW
motion sensor detects movement
activates hardware
camera
facial recog
-MUST BE FACE
if face does not match owner
then start wireshark/ aircrack-ng
measure flags per second from each source
notes new sources that have appeared since the last time the program ran.
-progam must run periodically as well to document sources around it.
each new source needs to be documented and stored in a database
after new sources are documented
mobile sources need to be identified
once sources are identified, they must be duplicated from 'NEW SOURCE" data row to "new mobile source" data row once source is documented it is passed to the outside program that begins sending de-auth packets,
document handshakes sent from de-authorized device,
use info to monitor that device
(this is project is for ethi
