The Vegas Project
Sometimes you have to just start over....
0 followers
This is the *rebuild* of the Vegas smart home, having lost most of my development files.
This project is starting with a proper base, a linux based router, that has all the anti phishing, anti bullcrap built-in, it should netboot stuff, serve files, and eventually run the new home automation platform.
Instead of installing all the tools to do so on a host platform, we are putting it all inside of docker.
The goal is to keep all the exposed services to a minimum, and any service that is exposed should be locked in a container, and have a restrictive apparmor profile.
github is being set up now for this.
  • 1 × Standard PC case It had a 350w PSU in it!
  • 1 × Random PC hardware
  • 1 × HP NC364T NIC 4 port gigabit PCIe
  • 1 × Goliton NIC 1 port gigabit PCIe
  • 1 × "3d sound" usb audio DAC 10 for $6 us!
  • To quote Poe...
    James Wynhoff09/25/2018 at 17:06 0 comments
    “I became insane, with long intervals of horrible sanity.”
    ― Edgar Allan Poe
    Due to a combination of lack of sleep, working in dimly lit conditions, and the stress of the new baby, there was an accident.
    No-one was harmed.......... unless you count Hulk, Titan, and Bench. Those are all the servers that were connected to the big boy UPS, you know, the one with 4 car batteries...
    With such a high amount of amps floating around with a ****few**** unsafe spots that expose dangerous points, I guess its a good thing that's all that happened!
View project log
