Mimicking Deep Note
A project log for Deep Synth
Synth riffs on the THX Deep Note.
bob-millerBob Miller 10/02/2018 at 14:580 Comments
To make a synth that sounds like Deep Note, first I need to understand Deep Note.  Fortunately, Batuhan Bozkurt has analyzed Deep Note and has published a good approximation of the sound.  Unfortunately, he used a synthesis language called SuperCollider.  I didn't know anything about SuperCollider.
SuperCollider is a declarative programming language for describing audio processing engines.  Its basic numeric type is a tensor, much like APL and NumPy.  It has high level primitives like oscillator, filter, envelope generator, etc.
But SuperCollider is open source, so it's easy enough to extract the relevant algorithms.  "Easy enough" in this context means a week or two of learning SuperCollider concepts, grepping through code, exploring blind alleys.  Free Software is both free as in freedom and free as in all your free time.
The overall architecture is like this.  There are 32 voices. Each voice is a sawtooth oscillator, a low pass filter, and a panner. Each osc. starts out randomly drifting between 200 and 400 Hz, then as the voices converge to the big chord, it sweeps toward its place in the chord.  The filter tracks the oscillator's frequency, with its cutoff frequency six times higher.  The panner puts the oscillator at a fixed, random position between the stereo channels.
All voices are mixed together, then the mix is low pass filtered and attenuated. The global filter starts at 2KHz, and gradually opens up to 20KHz.  The global attenuator starts at zero, then opens up over a 12 second period.
So I reimplemented it in C.  At first, I just ran it on my Mac -- the edit-compile-test cycle is faster there.  Then I ported the C code to the 1UP.
SuperCollider uses 2nd order biquad filters.  I started out with those, then switched to state variable filters.  The SVFs are more efficient when the cutoff frequency is changing.  These filters' cutoffs are always changing.
Note: I know nothing about DSP.  Whenever I say something like "biquad filter", you may safely assume that I'm just parroting something I read somewhere.  I wouldn't know an actual biquad filter from my own grandmother.  But I can read code, so if I see code purporting to be a biquad filter, I can analyze and transform it as code.
One thing I never did figure out was SuperCollider's sawtooth oscillator. It appears to be a perfectly bandlimited sawtooth (as opposed to a filtered one) created as the ratio of two sine waves, integrated.  The denominator is the oscillator's fundamental frequency, and the numerator is the highest odd harmonic below the Nyquist frequency. But that makes no sense to me.  I tried for too long to extract working code from SuperCollider, but failed.
I ended up using an aliased sawtooth oscillator instead.  Sorry. The low pass filter removes most of the aliasing, and the limited bit depth gets most of the rest.
So that's Deep Note analyzed and implemented.  The next challenge is to make something that plays more than one note.
