GAL Parse
Reverse engineering CPLDs
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
You can use a CPLD programmer to read back a CPLD - provided it is not encrpyted. The standard output file is a JEDEC fail usually with a .jed extension,
In this project we can read GAL 22v10s and reproduce a source file compatible with the CUPL compiler.
