ICS-43434 MEMS Microphone
A project log for Random-Ass Breakouts
What's a breadboard?
jarrettJarrett 11/05/2018 at 20:142 Comments
@Kris Winer used this sensor on the #STM32L4 Sensor Tile, and it looks pretty interesting for an application I have in mind.
I was originally, a long time ago, going to use a different electret microphone (the SPM0408LE5H-TB-6), but that was analog output, no amplification, nothing special.
This thing is a complete package, with I2S output. Seems awesome.
@oshpark link:
https://oshpark.com/shared_projects/22CwXvUR
Shown with a Digikey ruler. I'm liking this for scale, I might do it all the time.
Problems:
That hole for the microphone wasn't wide enough to actually be a hole. It was filled up with dried soldermask. A small drill bit cleared that right up. Note to self, make the hole bigger in my footprint. It's currently not a via, and it's probably best to keep it that way so as to not encourage solder to flow into the hole.
Kris Winer wrote 11/05/2018 at 23:22 point
Other problems: I don't see a bypass capacitor on VCC nor a 100 K resistor on SD to GND to allow the voltage to drain when the data line is deselected. Take a look at the datasheet to understand why these two might be important. Missing these doesn't mean the mic won't work, it just means it won't work well....
Jarrett wrote 11/05/2018 at 23:25 point
Excellent corrections, thanks!
It's clear that I haven't more than the most cursory glance at the datasheet so far :P
