So I finally got the wood I needed to start building the actual frame for the simulator.
For the buttom plate I used a big 1000X2000 cm particle board, the actual framing is made with 38X57 mm lathes.
The vertical lathes is attached to the buttom plate with angle brackets, then it was just a matter of filling in the gabs between them with the horizontal lathes making a square box to mount the parts on.
Then I started covering the frame with pices it partickel board , very simpel just cut to size with a jigsaw and screwed on to the lathes.
I then mounted the steering bracket / pedal assembly on to the frame, this was done using the original Scania mounting bracket by drilling holes in the lathes and screwing it all together with some big bolts I had leftover from a mailbox
