Last update to this log: 13.12.2018
Added link to a small USB UART adapter by @Jan--Henrik
Files
sending_file_at_256000baud.mp4Video of sending a 570kilobyte file (CSV) from the CH330N connected to my laptop to a FTDI 232RL also connected to the laptop. Speed: 256000BAUD, real speed is around 27KiB/secondMPEG-4 Video - 4.15 MB - 11/21/2018 at 18:06 |
CH330N.libCH330N KiCAD schematic symbollib - 578.00 bytes - 11/19/2018 at 18:26 |
CH330DS1.zh-CN.en.pdfDatasheet translated by https://www.onlinedoctranslator.com, 19.11.2018Adobe Portable Document Format - 155.84 kB - 11/19/2018 at 16:24 |
CH330DS1.pdfDatasheet (Chinese), downloaded 19.11.2018. Source: www.wch.cn/download/CH330DS1_PDF.html. Copyright wchAdobe Portable Document Format - 101.99 kB - 11/19/2018 at 16:21 |
ShareDiscussions
I received 10x wch330n chips yesterday, but in SOP8 format!
I am now hunting to see if I can find them in SOIC8 format, which is bigger to solder, as they appear on this HD article: https://hackaday.com/wp-content/uploads/2018/10/ch330.png
Will try to see if I can embed them in a simple USB plug, or just solder them on a stripboard and solder some wires for a salvaged USB plug.
The V3 test results are really useful - thanks for sharing!
I noticed that some vendors offer a "pin compatible" CH340N. Have you come across that chip?
Nice, thanks! I think you should have drawn more attention to a compelling feature of this chip, the built-in oscillator, which saves quite a few components.
On the H2O2 from Tindie, the V3 pin is not connected to 3.3V but only decoupled to GND for 3.3V operation. http://h2o2fromh2o.oregonsouth.com/Tindie/H2O2USBCH330N33/H2O2USBCH33033SerialProgramerSchematic.pdf
Is connecting V3 to 3.3V really required?
Not sure if this was available at the moment of writeup, but now it `clearly` states in datasheet "Connect to VCC to input external power when 3.3V power supply, connect to 0.1uF decoupling capacitor when 5V power supply". This pin is an internal 3.3 voltage reference for USB operation. Therefore either internally generated or tied to external 3.3v reference, whenever possible
