Initial notes
A project log for nedoPC-5
DIY personal computer built around 32-bit version of RISC-V processor
shaosSHAOS 11/20/2018 at 02:290 Comments
RV32I[MA] emulator with ELF support (RV32M and RV32A are optional)
https://gitlab.com/nedopc/npc5/blob/master/emu-rv32i.c
gcc -O3 -Wall -lelf emu-rv32i.c -o emu-rv32i
Passed RV32I compliance tests from https://github.com/riscv/riscv-compliance
make RISCV_TARGET=spike RISCV_DEVICE=rv32i TARGET_SIM=/full/path/emulator variant
Running simple code:
riscv32-unknown-elf-gcc -O3 -nostdlib test1.c -o test1
or
riscv64-unknown-elf-gcc -march=rv32i -mabi=ilp32 -O3 -nostdlib test1.c -o test1
then
./emu-rv32i test1
Hello RISC-V!
How to build RISC-V toolchain
https://riscv.org/software-tools/risc-v-gnu-compiler-toolchain/
Latest one is GCC 8.2.0
64-bit universal version (riscv64-unknown-elf-* unsuitable for Zephyr):
./configure --prefix=/opt/riscv
make
32-bit version (riscv32-unknown-elf-* suitable for Zephyr):
./configure --prefix=/opt/riscv32  --with-arch=rv32gc --with-abi=ilp32
make
RTOS Zephyr v1.13.0
https://github.com/zephyrproject-rtos/zephyr/releases/tag/zephyr-v1.13.0
It requires newer versions of CMake and DTC than my Debian had and also you need to do couple modifications for GCC 8.2.0:
1) lib/libc/minimal/include/sys/types.h:
change
#elif defined(__riscv__)
to
#elif defined(__riscv)
 2) add to the end of zephyr-env.sh:
export ZEPHYR_TOOLCHAIN_VARIANT=cross-compile
export CROSS_COMPILE=/opt/riscv32/bin/riscv32-unknown-elf-
Zephyr example:
cd zephyr
source zephyr-env.sh
cd samples/synchronization
mkdir build && cd build
cmake -GNinja -DBOARD=qemu_riscv32 ..
ninja
emu-rv32i zephyr/zephyr.elf
Thanks to @Frank Buss for source code of emulator and howtos!
