Finally, results
A project log for Lerdge 3d Printer Mainboard Hacking
Breaking the encryption on the Lerdge series mainboards so I can try porting Marlin 2.0 to it.
jc-nelsonJ.C. Nelson 12/05/2018 at 07:350 Comments
As I went back to basics and began looking at what the output was showing me, i noticed something. If I decrypted a value twice, I got the right entry. This is a fairly good indicator there was a problem with the python script that assembled my hacked ram data, and with one twist (changing the order) I generated a new table.
Immediately i was able to decrypt the lerdge firmware and see that it did appear to be valid code. All the strings decrypted perfectly.
The bootloader also decrypted fine.
Now I need a test subject with a lerdge x board who has already reset their bootloader to burn it on, and to do that, I reached out to the open lerdge people.
We shall see what happens next.
