v2.1
A project log for VHDL library for gate-level verification
Collection of ASIC cells and ProASIC3 "tiles" in VHDL so I can design and verify optimised code without the proprietary libraries
yann-guidon-ygdesYann Guidon / YGDES 08/17/2019 at 18:390 Comments
The v2 is already a significant breakthrough but instead of packaging/testing/integrating, I consider adding even more powerful features, in particular to provide an even better function ! I don't want to merely check if/how test vectors cover a design, now I want to generate these test vectors !
I have the stem of the algorithm but the system requires some more "updates" and I have to solve some thorny VHDLities : so many things are possible AND impossible, it's sometimes like a maze...
Anyway, I now add a "hidden port" to ALL the gates, to allow automatic discovery of the DUT's netlist, which is one of the required features to build the TVG algorithm.
Update : in fact, no need of a hidden port, I might have found a more elegant solution. We'll see when v2 is operational.
