The way to v2.3
A project log for VHDL library for gate-level verification
Collection of ASIC cells and ProASIC3 "tiles" in VHDL so I can design and verify optimised code without the proprietary libraries
yann-guidon-ygdesYann Guidon / YGDES 11/21/2019 at 00:560 Comments
Hopefully, v3 would implement some sort of ATVG but this is a complex algorithm with several steps, the first of them is to extract the netlist from the "blackbox" of the DUT (Design Under Test). The current version 2.2 is not yet able to do that and the chosen approach is to not analyse the DUT's file themselves, but only use "functional/behaviour" data obtained from 1) running the DUT 2) extracting and injecting information at the inputs/outputs and the gates themselves.
To extract the netlist, I don't intend to use simulator-provided internal feature. I have chosen the following "greybox" method :
The current code requires many modifications to permit this : for example, the lookup functions in the gates will be deeply altered and the global list of gates will have to hold much more information, in a better structured way. I also want to get rid of the the various architectures of gates and merge some code, which will make the library easier to use and probably even smaller. Hopefully I can find an easy yet efficient way to avoid having the "trace" architecture.
And of course, I must add the ALU8 as a 3rd example :-)
Let's do it...
Here it is ! A3Ptiles_v2.3_20191121.tgz
It's only a preliminary version where there is only a single architecture, more upgrades will follow.
