The lasted developments seem to be successful !
v2.6 is progressing and I can already list not only the gates but their interconnections !
13x A3P gates found. no exclusion input file to read. Input vector : 8 bits, Output vector : 9 bits Netlist : fixed ************ NETLIST ************ - Input #0 : fanout=4 1 : Gate #1(0) - inc8(tiles):e_r0b@inv(trace):lut2 2 : Gate #2(0) - inc8(tiles):e_r1b@xor2(trace):lut4 3 : Gate #3(0) - inc8(tiles):e_r2b@ax1c(trace):lut8 4 : Gate #4(0) - inc8(tiles):e_r3a@and3(trace):lut8 - Input #1 : fanout=3 1 : Gate #2(1) - inc8(tiles):e_r1b@xor2(trace):lut4 2 : Gate #3(1) - inc8(tiles):e_r2b@ax1c(trace):lut8 3 : Gate #4(1) - inc8(tiles):e_r3a@and3(trace):lut8 - Input #2 : fanout=2 1 : Gate #3(2) - inc8(tiles):e_r2b@ax1c(trace):lut8 2 : Gate #4(2) - inc8(tiles):e_r3a@and3(trace):lut8 - Input #3 : fanout=4 1 : Gate #5(0) - inc8(tiles):e_r3b@xor2(trace):lut4 2 : Gate #6(0) - inc8(tiles):e_r4a@and2(trace):lut4 3 : Gate #7(1) - inc8(tiles):e_r4b@ax1c(trace):lut8 4 : Gate #8(0) - inc8(tiles):e_r5a@and3(trace):lut8 - Input #4 : fanout=3 1 : Gate #6(1) - inc8(tiles):e_r4a@and2(trace):lut4 2 : Gate #7(2) - inc8(tiles):e_r4b@ax1c(trace):lut8 3 : Gate #8(1) - inc8(tiles):e_r5a@and3(trace):lut8 - Input #5 : fanout=3 1 : Gate #9(2) - inc8(tiles):e_r5b@ax1c(trace):lut8 2 : Gate #10(1) - inc8(tiles):e_r6a@and3(trace):lut8 3 : Gate #8(2) - inc8(tiles):e_r5a@and3(trace):lut8 - Input #6 : fanout=2 1 : Gate #11(2) - inc8(tiles):e_r6b@ax1c(trace):lut8 2 : Gate #10(2) - inc8(tiles):e_r6a@and3(trace):lut8 - Input #7 : fanout=2 1 : Gate #12(2) - inc8(tiles):e_r7a@and3(trace):lut8 2 : Gate #13(2) - inc8(tiles):e_r7b@ax1c(trace):lut8 - Gate #1 : fanout=1 Depth= LUT="10" - inc8(tiles):e_r0b@inv(trace):lut2 1 : Output #0 - Gate #2 : fanout=1 Depth= LUT="0110" - inc8(tiles):e_r1b@xor2(trace):lut4 1 : Output #1 - Gate #3 : fanout=1 Depth= LUT="01010110" - inc8(tiles):e_r2b@ax1c(trace):lut8 1 : Output #2 - Gate #4 : fanout=6 Depth= LUT="00000001" - inc8(tiles):e_r3a@and3(trace):lut8 1 : Gate #5(1) - inc8(tiles):e_r3b@xor2(trace):lut4 2 : Gate #7(0) - inc8(tiles):e_r4b@ax1c(trace):lut8 3 : Gate #9(0) - inc8(tiles):e_r5b@ax1c(trace):lut8 4 : Gate #11(0) - inc8(tiles):e_r6b@ax1c(trace):lut8 5 : Gate #12(0) - inc8(tiles):e_r7a@and3(trace):lut8 6 : Gate #13(0) - inc8(tiles):e_r7b@ax1c(trace):lut8 - Gate #5 : fanout=1 Depth= LUT="0110" - inc8(tiles):e_r3b@xor2(trace):lut4 1 : Output #3 - Gate #6 : fanout=2 Depth= LUT="0001" - inc8(tiles):e_r4a@and2(trace):lut4 1 : Gate #10(0) - inc8(tiles):e_r6a@and3(trace):lut8 2 : Gate #9(1) - inc8(tiles):e_r5b@ax1c(trace):lut8 - Gate #7 : fanout=1 Depth= LUT="01010110" - inc8(tiles):e_r4b@ax1c(trace):lut8 1 : Output #4 - Gate #8 : fanout=1 Depth= LUT="00000001" - inc8(tiles):e_r5a@and3(trace):lut8 1 : Gate #11(1) - inc8(tiles):e_r6b@ax1c(trace):lut8 - Gate #9 : fanout=1 Depth= LUT="01010110" - inc8(tiles):e_r5b@ax1c(trace):lut8 1 : Output #5 - Gate #10 : fanout=2 Depth= LUT="00000001" - inc8(tiles):e_r6a@and3(trace):lut8 1 : Gate #12(1) - inc8(tiles):e_r7a@and3(trace):lut8 2 : Gate #13(1) - inc8(tiles):e_r7b@ax1c(trace):lut8 - Gate #11 : fanout=1 Depth= LUT="01010110" - inc8(tiles):e_r6b@ax1c(trace):lut8 1 : Output #6 - Gate #12 : fanout=1 Depth= LUT="00000001" - inc8(tiles):e_r7a@and3(trace):lut8 1 : Output #8 - Gate #13 : fanout=1 Depth= LUT="01010110" - inc8(tiles):e_r7b@ax1c(trace):lut8 1 : Output #7 ************ END OF NETLIST ************
This is the netlist extracted from the INC8 unit and it's getting better and better. It matches well with the schematic :
I'm polishing things and I should add a few things :
- histogram of the fanouts...
- find a way to activate/trigger a given LUT entry
- "compile" the "depth" and check for loops or disconnected stuff
The latest update has a few enhancements and the ALU8 passes the netlist extractor :-)
