Register Memory Function Test
A project log for The Spikeputor
I am building a computer featuring a 16-bit RISC CPU made of discrete transistors for learning, fun and art. It will be pretty large.
spudfishscottspudfishScott 01/18/2019 at 22:080 Comments
I'm almost completely finished with Register Memory. All there is left is to finish the final three-bit boards for four registers (you can see these as "wire only" breadboards on the far left). Meanwhile, here's a video of a quick test. I used an Arduino to make clock pulses and to put a random number at the Register Memory Input on each cycle. I used another Arduino to pick a random register to write to and two random registers to send to the Channel A and Channel B outputs. So far, so good!
