Tensorrt on a jetson nano
A project log for Auto tracking camera
A camera that tracks a person & counts reps using *AI*.
lion-mclionheadlion mclionhead 02/19/2023 at 06:090 Comments
The journey begins by reading through
https://github.com/NVIDIA-AI-IOT/trt_pose
Your biggest challenge is going to be installing the pytorch dependencies as described on
https://docs.nvidia.com/deeplearning/frameworks/install-pytorch-jetson-platform/index.html
Some missing dependencies:
apt install python3-pip libopenblas-dev
pip3 install packaging
python3 -m pip install --no-cache $TORCH_INSTALL failed.
The TORCH_INSTALL variable has to be set to the right wheel file for your python version.  There's a list of wheel files for the various jetson images on
https://forums.developer.nvidia.com/t/pytorch-for-jetson/72048
The lion image was jetpack 4.6 which has python 3.6, so the wheel file for that version was
torch-1.9.0-cp36-cp36m-linux_aarch64.whl
The lion kingdom cut & pasted bits from the live_demo.ipynb file to create an executable. The live_demo requires many more dependencies
python3 -m pip install Pillow      # PIL errors
python3 -m pip install torchvision
pip3 install traitlets
pip3 install ipywidgets
You have to install the jetcam module with git
https://github.com/NVIDIA-AI-IOT/jetcam
The live_demo program only works inside a web app.  The best it can do without bringing up a lot more bits is process JPG images.
It supports multiple animals, but it's trash at detecting body parts.  Changing the aspect ratio gives different but equally worthless results.
The demo without a browser can give a rough idea of the framerate.  The frame rate seemed to be in the 12-15fps range.
There is another program which exposes somewhat of a C++ API for trt_pose, but with the same model.
https://github.com/spacewalk01/tensorrt-openpose
Acceptable quality seems to require the original openpose at 5fps.  The jetson might be good enough to run efficientdet & face recognition on the truckcam.  It's not good enough for rep counting & camera tracking.  The most cost effective solution is going to be a gaming laptop more than any embedded confuser.
