Specs
  • Work Space: 4' X 8' *
  • Encoder Resolution: 8148 steps/rev
  • Real World Precision: +- 1/64th inch (.4 mm) or better
  • Max feed rate 48 inches/minute
  • AC Voltage: 110-250 volts
  • DC Voltage: 12 volts
  • Connection: USB
  • OS for Software: Mac, Windows, Linux
*The work space is defined by the length of the two #25 roller chains so it can be easily enlarged or made smaller by adding or removing links from the chains.
Here's a video of me running through the design:
Find out more and watch videos of the machine in action on our website www.maslowCNC.com or check out our source code (firmware and software), PCB layouts, and CAD files at https://github.com/MaslowCNC
