I2C code  based on interrupts , no polling code.
I2C Clock Speed 100Khz
Address 0x32 (editable at HEX file)
Commands
MOTOR_GET_COUNT 0x02: Send 0x02, Read int32 (4 bytes)
MOTOR_SET_COUNT 0x03: Send 0x03 int32 (5bytes)
MOTOR_SET_TARGET 0x04: Send 0x04+ int32 (total 5bytes)
MOTOR_GET_TARGET 0x05; Send 0x05, Read int32 (4 bytes)
MOTOR_SET_TICKS 0x06: Send 0x06+ int32 (total 5bytes)
MOTOR_SET_DIR_RES 0x07: Send 0x07+ int32 (total 5bytes)
 MOTOR_SET_PRESCALER 0x08:Send 0x08+ int32 (total 5bytes)
MOTOR_SET_WAVE_SCALE 0x09:Send 0x09+ int32 (total 5bytes)
MOTOR_SET_SPEED:0x0A:Send 0x0A+float (total 5bytes)
MOTOR_SET_TARGET_SPEED 0x0B:Send 0x0B+float (total 5bytes)
MOTOR_GET_TARGET_SPEED 0x0C
MOTOR_GET_SPEED 0x0D
MOTOR_GET_DIR_RES 0x0e
Values for set speed microsteps/s signed  4 bytes float
SET_SPEED set speed with no acceleration SET_TARGET_SPEED accelerate from current set speed.
Speed timer frecuency 48khz tick 20,8us At this moment only min value -65535 to +65535 speed 65535-> 1,3s per microstep positive direction speed 30000->0,65s per microstep positive direction speed -15000->0,3125s per microstep negative direction
Resolution 1-> 32 msteps 2->16 4->8 8->4 counter is always 32 microsteps resolution
Arduino test code (works on AVR and esp8266)
#include <Wire.h>
#define SLAVE_ADDRESS_1 0x32
//Set Commands
#define MYSLAVE_SET_REG 0x01
//GET commands
#define MOTOR_GET_COUNT 0x02
#define MOTOR_SET_COUNT 0x03
#define MOTOR_SET_TARGET 0x04
#define MOTOR_GET_TARGET 0x05
#define MOTOR_SET_TICKS 0x06
#define MOTOR_SET_DIR_RES 0x7
#define MOTOR_SET_DIR_RES 0x07
#define MOTOR_SET_PRESCALER 0x08
#define MOTOR_SET_WAVE_SCALE 0x09
#define MOTOR_SET_SPEED 0x0A
#define MOTOR_SET_TARGET_SPEED 0x0B
#define MOTOR_GET_TARGET_SPEED 0x0C
#define MOTOR_GET_SPEED 0x0D
#define MOTOR_GET_DIR_RES 0x0e
#define PRINT_WAVE 0x44
void setup() {
 Wire.begin();        // join i2c bus (address optional for master)
 Serial.begin(9600);  // start serial for output
int32_t read_wms( uint8_t command, int address)
{ int32_t pos;
  char *pointer;
  char c;
  pointer=(char*)(&pos);
 Wire.beginTransmission(address);
  Wire.write(command);
  Wire.endTransmission();
  delay(5);
   Wire.requestFrom(address, 4);
    while (Wire.available()) {
    char c = Wire.read();
    (*pointer++)=c;
    return pos;
void write_wms( uint8_t command, int address,int32_t value)
  char *pointer;
  pointer=(char*)(&value);
  Wire.write( command);
  Wire.write(pointer,4);
void write_wmsf( uint8_t command, int address,float value)
  char *pointer;
void loop() {
 //goto from 0 to 1000
 int32_t pos=0;//set motor counter to 0
 int32_t target= 10000;//set desired position 10000
 int32_t speed=300;//20,8 us * 300 =0.624s  ->16,02 microsteps/s
 float speedf=2000.0;//2000 msteps/s
 write_wms(MOTOR_SET_COUNT,SLAVE_ADDRESS_1,pos);//send counter
 write_wms(MOTOR_SET_TARGET,SLAVE_ADDRESS_1,target);//target set
// write_wms(MOTOR_SET_TICKS,SLAVE_ADDRESS_1,speed);//command speed
 write_wmsf(MOTOR_SET_SPEED ,SLAVE_ADDRESS_1,speedf);//command speed
 while ( (pos=read_wms( MOTOR_GET_COUNT ,SLAVE_ADDRESS_1))!=target)
  delay (100);
  Serial.println(pos);}
//motor will turn an stop until reach 1000 counter value
//now we command back 0 pos
  target= 0;//set desired position 1000
 speedf=-2000;//20,8 us * 300 =0.624s  ->-16,02 microsteps/s
 int32_t resolution=2; //motor will no run on 16 msteps
 write_wms(MOTOR_SET_DIR_RES,SLAVE_ADDRESS_1,resolution);
  delay (100);
