2nd PCB - it's alive!
A project log for FORCE - Force Output of Rodent Calibrated Effort
This dual-force cell monitor and reward dispenser is used to run rodent operant behavior in which animals learn to work for rewards.
lex-kravitzLex Kravitz 02/23/2019 at 20:240 Comments
The problem with the first PCB was that the ground pin on one of the force cell amps wasn't connected!  It was on an island of copper, and thereby didn't connect up with the ground plane.  I re-oriented the force cell amps and everything is working now!
Next step is to integrate 3.3V solenoid control for dispensing liquids, using a circuit we've previously built:
https://hackaday.io/project/156847-simple-pcb-to-control-a-33v-solenoid
And then spin a nice purple board!
