Continue with a week 5, start to sketch out the design for the project, before start to build the real things, these have to think how the idea can work, function, process, result from start to end of idea work, exterior, and also I have to make some experiment to make sure the idea can work.
1. Design exterior
-the exterior is have to measuring approximate length, and also how it's actually looks like, basically is on the box to represent it, inside have lights to illuminate the shadow of the figure, same as the concept like "Wayang Kulit."
2. How it's work
-to sum up how to Inadvertently hurt peoplecarry out the function of the projects, arduino have to use 1 sound sensor, 1 DC motor, some servo motor only. Sound sensor is use for the volume of the sound, it also connect to the DC motor and servo motor, because after makes a specified volume, all the motor will automatic start to work until repeat all the process.
3. Why volume?
- to show out the "sharp of mouth" is not only used some bad word to represent it, the sound volume also can represent the "sharp of mouth" because when we angry and blame some people, the sound tone express the angry people easy inadvertently hurt people.
