Before start the work process, have to confirm all the things should work, where should stick the motor, or what are the material can sue to create it.
-Start from doing the figure out first, try how the figure will work when control by DC motor and servo motor, the following is some work in progress that using laser cut to cut the figure, use different size of figure to experiment the project.
