Continue with week 11, now is during testing of the lighting and the sound sensor. The lighting is ok for illuminate, but the distance also will influences the clearer of shadow, so the lighting move on far a bit is battle and clear to see the shadow, compare with the first the lighting too near will make the light more clearer then shadow,
-Front view of the box.
-on the left middle is the hole for the sound sensor
-The sound sensor has no problems after done the many testing of connecting.
-At first sound sensor have experiment to try switch on the LED light, so that mean sound sensor has no abnormal.
-The final view for this sound sensor will be embellish.
-Overall the box also will be embellish nicely.
