When during the operation, the Arduino Nano has burn by no reason, this maybe happened suddenly, but does not affect to the all projects, but have to find the new Arduino for replace, lucky change to Arduino Uno to continue.
-The Arduino Nano has be burning.
-Arduino UNO to replace.
-Fixing the Arduino and L298N in the box.
-After change to Arduino UNO have to add on the L298N again to avoid the Arduino burn again.
-After confirm all the things is working normally, then can do the design part for overall view.
-Need to build one box to connect with main box because the lighting must make sure can illuminate the figure, and also cant not just left it their with entry space.
-So far the projects has wasted a lot wire and some material but the budget has no more then RM50, their also have many failed goods to testing and do this projects.
