Depression piano
Finally everything works
This is the depression piano
First you need to plug in the knife.
Then tune up the volume.
After tuning up the volume the hologram shows .
Then you can press the key.
After pressing the key it will start raining and come with the sound.
everything almost done but some of the key doesn’t work very well
start doing final installation, but haven’t start soldering all the led light
doing final prototype in case something happens.
Making a support for the volume tuner to make the tuner spin well.
Support links: https://www.tinkercad.com/things/bc1dsLPy6kn-exquisite-amberis
nothing special, just keep trying around and testing around.
Have printed out the piano key with lab piano key open source 3D model.
Piano key link:https://www.myminifactory.com/object/3d-print-nintendo-labo-piano-keys-improvements-66791
Finish 95% of the code.
Prototype in progress.
Made a volume tuner to attach to my tuner, after print it out it feel the tuner is too small, so I make a cap to make it bigger.
Tinkercad link: https://www.tinkercad.com/things/bc1dsLPy6kn-exquisite-amberis
sound design in progress.
Walk cycle done.
character silhouette walk cycle drawing in progress.
Trying to make the code work more smooth.
1. Generative rain code is working.
2.Have brought a tuner for my arduino.
1. Have ordered the 7” monitor
2. Had brought 1 A0 size 2mm black colour acrylic board
View all 15 project logs
Naman Pushp
David Troetschel
TAIBHSE DESIGNS
Ignacio Acosta Pineda
Yes, delete it Cancel
You are about to report the project "Dynamic interactivity final project ", please tell us the reason.
