YamPAD project log 8
A project log for YamPAD - Feature-packed open source macropad
A fully open-source, mechanical, hot-swappable, RGB backlit, QMK powered, OLED screen featuring numpad/macropad.
mattia-dal-benMattia Dal Ben 05/26/2019 at 11:542 Comments
Some case design...
Finally, after a few iterations, I came up with a design I like. The main problem is the screw holes, I'm worried about the acrylic structural integrity after removing that much material from the corners. We'll see...
Here's some renderings...
Let's see how it turns out...
Rupert Hirst wrote 05/30/2019 at 22:13 point
Great project :)
The radius on the corners is too large and not in proportion to the screw holes.  Is there a reason for such a large radius?
Mattia Dal Ben wrote 05/31/2019 at 05:16 point
Actually there's no reason for that radius apart from the fact that I thought it looked nice. I'll try to make the corners sharper as you suggest.  Thanks for the feedback, much appreciated :)
