YamPAD project log 15
A project log for YamPAD - Feature-packed open source macropad
A fully open-source, mechanical, hot-swappable, RGB backlit, QMK powered, OLED screen featuring numpad/macropad.
mattia-dal-benMattia Dal Ben 06/30/2019 at 18:200 Comments
Failure...
After the first success in cutting the aluminium I started fine tuning my parameters. Turns out I bought some baaaad aluminium (1050A) because I'm cheap. Thanfully a hero on the internet found the best parameters for the 1050 aluminium and I adopted them:
I cut my machining time from >2hr to 30min thanks to these. I'm super happy with them.
Problem is: I failed to cut the plate anyway :(
The aftermath...
The most likely suspects.
In the final cut (it's alwasy the final operation...) I started losing steps during a Y straight cut. I think the aluminium chips and WD-40 mixture started jamming the wheels of the mill. Pics related.
Anyway, it's too late for another attempt for today. I'll give it a try next week, hoping in the mercy of the machining gods.
