Rev1 - Final test article
A project log for Open Source LiDAR - Unruly
We've been waiting a long time for someone to post the plans of a working LiDAR. Is it really going to happen?
laser-developerLaser Developer 01/20/2019 at 16:337 Comments
Rev1 is a stable test board for further software development. New features specifically for educational purposes have been added:
You will notice on the circuit board overlays that there are lots of small holes and very few visible tracks. The holes bridge the inner ground layers and outside layers together to reduce transmitted interference and cross talk between the laser driver and receiver circuits. The signal tracks are on the inner layers, shielded by ground plains, to reduce electromagnetic susceptibility.
Above is the top side of the board and below is the other side showing the pulsed laser diode (PLD) and the avalanche photodiode (APD). At the moment we're using a laser from Laser Components and an APD from Hamamatsu.
In order to test Unruly it's important to be able to access the components on both sides of the board while it is running. This is done by adding "wings" instead of headers. These wings are just headers soldered on at right angles.
The optics are then screwed on.
Using the wings, jumper cables connect the ItsyBitsy M4 Express to the Unruly LiDAR leaving the back of the circuit board accessible to an oscilloscope.
Test 1 - Unfiltered signal stability - indoors:
Results:
Single shot STDEV (standard deviation) = 1.0 cm (33 ps)
Single reading APD bias voltage measurement STDEV = 0.11 V
Single reading APD temperature measurement STDEV = 0.2 C
iliasam wrote 02/04/2019 at 12:16 point
Please, can you say the the settings of the device at witch you get this results (Test 1  - indoors) - APD voltage, IC5 gain, comparator threshold level?
Laser Developer wrote 02/04/2019 at 12:21 point
There are quite a range of values that can be used. For this test I used:
APD voltage = 120V
VGA gain = 14dB,
Comparator threshold = 50mV.
iliasam wrote 02/04/2019 at 12:57 point
Thank you for the information.
Jamie wrote 02/02/2019 at 00:07 point
If it were just a few, what would the realistic cost price be?
Laser Developer wrote 02/02/2019 at 05:08 point
Retail selling price US$120. We're hoping to finish the design of Rev2 today - this version has a different chip set that should be cheaper to manufacture but may have slightly reduced range performance. We have commitment from LightWare.co.za that if we can get the retail price below US$100 then they will make in batches of 100 at a time. Also RobotShop.com has expressed interest in distributing Unruly. Some way still to go to a finished product because we need tooling for the optical holder (US$20k).
Jamie wrote 01/31/2019 at 16:47 point
Are you going to make these available to sell?
Laser Developer wrote 02/01/2019 at 06:07 point
We are hoping so. It really depends on how much interest there is from the public. Some of the components are quite expensive so it probably isn't worth making just a few. I'll post new information as I get it.
