Quick Update - Basic Schematic Finished
A project log for The Super Sensor Breakout
Forgetting the cringeworthy name (I am open to suggestions), this is a breakout with what I think are the best 3 sensors (see details below)
louis-parkersonLouis Parkerson 01/22/2019 at 19:180 Comments
Just a quick update to say I have finished the basic schematic. Before I upload it to here I plan on adding some extra features to improve ease of use. Firstly,  I plan on adding MOSFETs so power is not wasted if you do not use a certain sensors as well as voltage regulators and logic level converters to allow the breakout to be used with a wide range of microcontrollers. Also, I also plan on adding buttons to the reset pins of the SHT35-D and BNO055.
