IR-only DepthAI
A project log for Luxonis DepthAI
Spatial AI Meets Embedded Systems
brandonBrandon 06/03/2020 at 20:530 Comments
Hi DepthAI (and megaAI) fans!
So we have a couple customers who are interested in IR-only variants of the global-shutter cameras used for Depth, so we made a quick variant of DepthAI with these.
We actually just made adapter boards which plug directly into the BW1097 (here) by unplugging the existing onboard cameras.  We tested with this IR flashlight here.
It's a bit hard to see, but you can tell the room is relatively dark to visible light and the IR cameras pick up the IR light quite well.
Cheers,
The Luxonis Team
