Selective breeding.
A project log for Christine's Blooming Rose
3D printed, heat formed, servo actuated blooming, Dotstar module lit, rose.
daren-schwenkeDaren Schwenke 02/14/2019 at 21:110 Comments
Left was the original hinge design.  A single braiding band wrapped just above the hinge provided enough spring tension to close the flower and held it all together.  Worked well, but used a wedge inside to push the flower open.  That made the petals stack up resulting in a flat rose.
Right was the revised design  Now pushing on the extended bit opened all the petals evenly.  Problem was it was over-constrained.
The hinge on the left was sloppy, and allowed the petal to flex left/right as the flower opened/closed.  I eliminated that flex in the second design, but that turned out to be important.
Opening does not trace a linear path as the curved surfaces engage each other, and the flex allowed the petals to slide over one another without binding.
So I need to cross-breed these two strains and I'll have the flower I need.  That will take more time than I have.
