3D Printing Gears and a Planetary Gearbox
Design of involute gear tooth profiles and hints and tips for 3D printing real gears to do work.
ob1ob1
This project describes the design and construction of a working planetary 3D printed gearbox from first principles. Gears are precision machines and their own right. While cogs with arbitrary
tooth profiles will probably work there may be good reasons for using an involute tooth profile.
Dan Maloney wrote 02/14/2019 at 15:32 point
Liked your write up, very good description of the geometry of involute teeth. One suggestion - pull some of the salient points from the blog post up into Hackaday.IO. I know it seems like duplication of effort, but it helps the community more than a link to another site would.
