step 2
A project log for Cheap, used parts build Mini PC
Cheap, used parts to build GNU/Linux (Ubuntu, Deepin) pocket PC
singsooosingsooo 02/25/2019 at 15:510 Comments
1. Disassemble the DELL G7L00 keyboard. Found cable using a conductive rubber, the secondary can not be repaired. The pins of the EM chip (8-bit microcontroller) are measured. Preparing the circuit design, using NRF5283. Transformed into a Bluetooth keyboard.
2.Z8300 motherboard to install ubuntu system boot problems. Looking for a solution. .
