Pre-order now! The first 100 pcs will be available at the end of November
A project log for Smart Speaker from Scratch
Make an open source smart speaker for daily use
yihuiYihui 11/04/2019 at 02:500 Comments
The first hardware kit of the project is coming! You can pre-order it at https://www.makerfabs.com/voicen-linear-4-mic-array-kit.html
The kit named VOICEN Linear 4 Mic Array lets you build a smart speaker from scratch. It can run a variety of voice assistants such as Amazon Alexa, Google Assistant, MyCroft, Snips Offline Voice Assistant and Baidu DuerOS. It supports AirPlay and UPnP/DLNA. You can turn it into a music box with Mopidy and MPD, or use it to automate your home with Home Assistant.
Specifications:
  • AllWinner H3 (Quad-Core ARM Cortex A7 @ 1.296 GHz)
  • 512MB RAM
  • 8GB eMMC Flash
  • 16GB Micro SD Card
  • 4 Channels ADC AC108
  • 4 MEMS microphones (64dB SNR, -38dB Sensitivity)
  • 4Ω 3W Loud Speaker
  • 4 LEDs (R, G, B, Y)
  • 1 Touch Key
  • 1 Paper Case
  • 1 Micro USB Cable
  • Applications:
  • Built a smart speaker with multiple voice assistants
  • Make a Wi-Fi speaker with AirPlay and UPnP/DLNA
  • Setup a multi-room audio system
  • Automate your home with Home Automation
  • Learn to use a variety of audio processing algorithms such as AEC, DOA, NS and Beamforming
  • Learn how to send data over audio
  • Discussions
