^5 Test Mode Self-Test Style From RPUno
A project log for RPUpi - a shield for tool-chain at network edge
Connects a Raspberry Pi to a serial multi-drop bus.
ronaldsutherlandronald.sutherland 07/11/2019 at 18:380 Comments
If the RPUpi were to be integrated onto an RPUno, I would want it tested with a self-test.
https://github.com/epccs/RPUno/tree/master/XcvrTest
That was a lot of effort; the good news is that it should mostly copy to my other boards which I plan to gradually integrate this into (and then ditch all sorts of headers). The 40 pin R-Pi interface will be my path forward, I have grown comfortable with what the R-Pi foundation is doing.
picocom -b 38400 /dev/ttyUSB0
picocom v2.2
Terminal ready
RPUpi Transceiver Test date: Jul 11 2019
avr-gcc --version: 5.4.0
I2C provided address 0x31 from manager
SMBUS cmd 0 provided address 49 from manager
MISO loopback to MOSI == HIGH
MISO loopback to MOSI == LOW
SCK with Shutdown loopback == HIGH
I2C Shutdown cmd is clean {5, 1}
SCK with Shutdown loopback == LOW
I2C Shutdown Detect cmd is clean {4, 1}
Testmode: default trancever control bits
I2C Start Test Mode cmd was clean {48, 1}
I2C End Test Mode hex is Xcvr cntl bits {49, 0xD5}
Testmode: read  Xcvr cntl bits {50, 0xE2}
PWR_I /w no load using INTERNAL_1V1: 0.024 A
Testmode: nCTS loopback to nRTS
Testmode: set  Xcvr cntl bits {51, 0xA2}
Testmode: read  Xcvr cntl bits {50, 0x22}
Testmode: Enable TX pair driver
Testmode: set  Xcvr cntl bits {51, 0xF2}
Testmode: read  Xcvr cntl bits {50, 0xF2}
PWR_I /w TX pair load: 0.044 A
Testmode: Enable TX & RX(loopback) pair drivers
Testmode: set  Xcvr cntl bits {51, 0xD1}
Testmode: read  Xcvr cntl bits {50, 0xD1}
PWR_I /w TX and RX pairs loaded: 0.066 A
RX loopback checked
Testmode: Enable DTR pair driver
Testmode: set  Xcvr cntl bits {51, 0xE6}
Testmode: read  Xcvr cntl bits {50, 0xE6}
PWR_I /w DTR pair load: 0.044 A
[PASS]
RPUpi^5 Self-Test Style
