Rebuilt Tarvo Korrovits' Acts Language compiler.
actsl.txt.gzTarvo Korrovits released source code (in C and ActsL) for his ActsL compiler.gzip - 3.90 kB - 03/15/2019 at 07:31 |
actsl.aTarvo Korrovits released ActsL source code for his ActsL compiler.application/x-archive - 20.15 kB - 03/15/2019 at 07:27 |
RPNC.cMy version of the tokeniser and parser.x-csrc - 6.00 kB - 03/15/2019 at 07:27 |
CodeGen.cMy version of the assembly code generator,x-csrc - 6.12 kB - 03/15/2019 at 07:27 |
CodeGen.hHeader file for the assembly code generator.x-chdr - 1.43 kB - 03/15/2019 at 07:27 |
As I parse the "self compiling" compiler I see just how ubiquitous "libc" is.
But I think I the "atomic" functions are:
Actually I only need a memory pointer to the "heap" for malloc() and free().
"feof()" makes the list as I need to know when input (serial) data is available.
I have actually coded in ActsL most of the functions I need:
Still more to code.
"fprintf()" is a complex and large procedure for a simple compiler.
As the arguments are variable, the count needs to be given to the function in some manner. Perhaps a global variable for the argument count or a NULL delimiter on the stack.
Better to use fputs() and construct a string using strcpy(), strcat() and itoa().
I was contemplating my TTA8 as a target (when I get it working!).
The memory page size is limited to 64 bytes but I have up to 255 pages. So it is doable.
I now have the "p code" (i.e CodeGen.h) specification for the CPU interpreter the emulate.
AlanX
Tarvo's original language specifications was:
So pretty complete, actually his "actsl.a" program self compiles.
Here is the "Hello World!" program in ActsL:
int rtn
int nul
int buff
fun init
ref rtn ref nul = // Make null point to nulv (i.e. nul=&nulv)
32 arg call malloc ref buff = // Create a buffer (buff) for your string
0 return
endfun
fun PutStr
buff arg call puts nul = // Print the buffer (buff)
0 return
endfun
fun main
call init nul = // Initialise variables
/* Copy "Hello World!" into a buffer (buff) */
"Hello World!" arg buff arg call strcpy nul =
call PutStr nul = // Call print string
0 return // Return okay
endfun
Okay, its a bit more complicated than it has to be but it show the language elements.
An example of "his" code (although I have played a bit with it!), first in C:
void error (char *text)
printf ("%s:%d: %s\n", infile, line, text);
exit (1);
Now in ActsL:
fun error
buff arg line arg infile arg "%s:%d: %s\n" arg call printf nul =
1 arg call exit nul =
endfun
In his ActsL code he has use "buff" instead of "text" (not important), but he fails to use a return statement (a bit lazy and it cost me time to work this out!), and "nul" has been assigned the address of "nulv" during the initialisation (otherwise he should have used "ref nul =" and not "nul =").
Note, if your not careful with assignment (i.e. "="), it is very easy to generate a segment fault and no idea where the code error is!
Finally you will see he uses "printf()" and "exit()" from "libc". So even though his code self compiles, you need to be aware that it still uses libc.
Although he can set arguments (i.e. "arg") for a call, an ActsL function (i.e. "fun"/"endfun") can not read then. Therefore I add:
Here is an example of its use:
... fun test1 1 param return endfun ... 98 arg 99 arg call test1 nul = rtn arg "\nReturn %d\n" arg call printf nul = ...
"fun test1" was called with two arguments (98 and 99), the first parameter (=99) was returned.
Next, I added "else" to the set of commands.
Next, I added "// .. '\n'" comments to the set of commands (I like having both).
Finally, I tokenised "halt" when the EOF is found.
And I nearly forgot, added support for "_" in names and negative integers.
All variables are global. This is a bit of a pain, so I use lower case for code and will use upper case for library code.
And if you have not worked out, delimiters are white spaces (i.e. " \t\n").
As I intend to port the code to one of my home brew CPUs, I will not have the luxury of access to libc. I have made a start on this.
AlanX
