I2c Testing
A project log for MIDI Drum Module (MkII)
A Roland-compatible drum module. Built using mostly off-the-shelf parts.
craig-hissettCraig Hissett 03/21/2019 at 00:500 Comments
Just a little update tonight, testing out my i2c premise.
The Mega successfully passes data to the Pro Micro, which is great news.
Now I just need to tighten it up and make sure it's fast and robust, then tidy up the Mega's pad reading code.
Then it'll be time to stick a load of Jack sockets in a box with lots of Arduinos ha ha!
