Routing the MCU
A project log for Möbius Flex
My entry for the flex PCB contest. I'm not sure how well a flex PCB will work for an LED-studded möbius strip, but let's find out.
chris-millerChris Miller 03/25/2019 at 22:390 Comments
I had already decided to use the VQFN version of the Atmega328p on this design. That gives me plenty of IOs and a simple way to program it through 6 pins.  I can also power the programmed device through the programming header's 5v and gnd pins.
Initially I thought the layout would be on both sides of the central hub.  I was looking at multiple resistor packs, smaller components, both sides, etc...  But it turns out that using 0603 passives, I was able to get the MCU, its supporting components, and 12 current limiting resistors on the top side of the 16x16mm main PCB.  I used the smallest 6mil tracks and spacing that OshPark supports for flex PCBs.  This allowed me to put all of the board interconnects and the programming header on the bottom for a clean look.
Central hub layout
