More assembling (Art2Bodies and Art3Body)
A project log for Building the Thor robot
Building a 6-axis robot based on the Thor robot. When size DOES matter!
olaf-baeyensOlaf Baeyens 12/29/2016 at 01:593 Comments
Today I was a happy man since I finally received the very long m3x50 screws and the 6 mm balls for the 3D printed ball bearings.
To hold the 2 Art2Bodies together it requires 8 very long M3X50 screws and nuts.
The upper part will have one metal axis, the lower part that drives the cogs will actually be 2 small axis endings that will get pressured in place by the midsection. I did had doubt this part would function well but now that I have the midsection assembled I am convinced that it will work.
I also received the 6mm balls for the 3D printed ball bearing for Art3Body. So I could assemble it.
(Note: This part has been photographed upside down to show the cogs)
Detail of Art4TransmissionColumn assembled with the 6mm balls that gets inserted through the hole (left side on the image). Once this part is inserted into Art3Body, the hole gets covered. However I put a piece of paper to block the entrance because I don't want the balls to drop when I disassemble.
AngelLM wrote 12/29/2016 at 15:02 point
Its taking shape!
Looking at your post I realized that I forgot to upload the Art4 ball-locking plug. I'll upload it ASAP :)
Olaf Baeyens wrote 12/29/2016 at 16:12 point
It is actually very rewarding to see it all starts to fit together and have it in your hands.
AngelLM wrote 12/30/2016 at 01:54 point
I just added the Art4BearingPlug file into GitHub repository :)
