New casing and buttons
A project log for ESPboy - RetroGaming&Software development MuliTool
For IT geeks, retro game fans, makers. Open source, portable, modular to explore, create, learn, code & play
romansRomanS 09/06/2019 at 09:060 Comments
Here is new version of casing with small brass screws, columns and buttons in form of screws.
You can easy put your ESPboy in the case anytime or use it without a case.
Can't find better solution. The previous red buttons looks better but you have to resolder SMD buttons at ESPboy's PCB and this larger buttos are close the USB port for uploading the firmware.
Waiting for assembled 10 ESPboys form China )
