• 1
    Set the clock and upload the sketch
    Upload the sketch using the Arduino UNO as SPI programmer. Use 1mm diameter pogo pins to connect to the board:
    Make sure to burn the bootloader with the clock set to 8MHz (internal). Compile the following sketch with LTO enabled (sketch will be too large when LTO is not used):
    #include <Arduino.h>
    #include <U8x8lib.h>
    #include <NewPing.h>
    #ifdef U8X8_HAVE_HW_SPI
    #include <SPI.h>
    #endif
    //U8X8_SSD1306_128X64_NONAME_4W_SW_SPI u8x8(/* clock=*/ 5, /* data=*/ 4, /* cs=*/ 1, /* dc=*/ 2, /* reset=*/ 3);
    U8X8_SH1106_128X64_NONAME_4W_SW_SPI u8x8(/* clock=*/ 5, /* data=*/ 4, /* cs=*/ 1, /* dc=*/ 2, /* reset=*/ 3);
    #define TRIGGER_PIN  7  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     8  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    char tmp_string[5];
    long voltage;
    void setup(void)
      pinMode(6, OUTPUT);
      pinMode(9, OUTPUT);
      digitalWrite(6, HIGH);
      digitalWrite(9, LOW);
      u8x8.begin();
      u8x8.setPowerSave(0);
    void loop(void)
      //read and convert the voltage to a decimal
      voltage = readVcc();
      double decimalVoltage = doubleMap(double(voltage),0,6000,0,6);
      //u8x8.setFont(u8x8_font_chroma48medium8_r);
      unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
      u8x8.setFont(u8x8_font_amstrad_cpc_extended_r);
      //u8x8.setFont(u8x8_font_profont29_2x3_r);
      u8x8.setCursor(10, 7);
      u8x8.print(decimalVoltage);
      u8x8.drawString(14, 7, "V");
      if((uS / US_ROUNDTRIP_CM) == 0){
        // do nothing, do not upate display
      else if((uS / US_ROUNDTRIP_CM) < 10) {
          u8x8.draw2x2String(1, 3, "  ");
          u8x8.draw2x2String(5, 3, itoa(uS / US_ROUNDTRIP_CM, tmp_string, 10));
      else if((uS / US_ROUNDTRIP_CM) < 100) {
          //u8x8.print(uS / US_ROUNDTRIP_CM);
          u8x8.draw2x2String(3, 3, itoa(uS / US_ROUNDTRIP_CM, tmp_string, 10));
      else {
          u8x8.draw2x2String(1, 3, itoa(uS / US_ROUNDTRIP_CM, tmp_string, 10));
      u8x8.drawString(8, 3, "centi-");
      u8x8.drawString(8, 4, "meters");
      u8x8.drawString(2, 1, "Distance:");
      delay(100);
    double doubleMap(double x, double in_min, double in_max, double out_min, double out_max)
      return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
    long readVcc() {
      // Read 1.1V reference against AVcc
      // set the reference to Vcc and the measurement to the internal 1.1V reference
      #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
        ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
      #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
        ADMUX = _BV(MUX5) | _BV(MUX0);
      #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
        ADMUX = _BV(MUX3) | _BV(MUX2);
      #elif defined (__AVR_ATtiny87__) || defined(__AVR_ATtiny167__)
      #else
        ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
      #endif
      delay(20); // Wait for Vref to settle
      ADCSRA |= _BV(ADSC); // Start conversion
      while (bit_is_set(ADCSRA,ADSC)); // measuring
      uint8_t low  = ADCL; // must read ADCL first - it then locks ADCH
      uint8_t high = ADCH; // unlocks both
      long result = (high<<8) | low;
      result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
      return result; // Vcc in millivolts
