I2C Pi OLED Usage
Miniature OLED display modules are a great way to add a small screen to your Raspberry Pi projects.
In this tutorial I’ll explain how I setup my 0.91″ OLED display module using the Pi’s I2C interface. Once setup it is easy to use Python to place text, draw shapes or even display simple images and animations.
PI OLED Module
The pi oled is 0.91 inch iic oled. Now you can get it here:
It is very easy to use. Just plug to your pi will ok.
  • 1 × I2C Pi OLED
  • 1 × Pi Zero w
  • 1
    Step 1
    PI OLED Module
    the pi oled is 0.91 inch iic oled.
    Update the pi system and Python
    Before use the pioled, please install the Raspbian or Raspbian Lite to your computer.
    Run the standard updates:
    sudo apt-get update
    sudo apt-get upgrade
    and
    sudo pip3 install --upgrade setuptools
    If above doesn't work try
    sudo apt-get install python3-pip
    Install the library for the Pi OLED
    enter the following into the terminal:
    sudo pip3 install adafruit-circuitpython-ssd1306
    If that complains about pip3 not being installed, then run this first to install it:
    Enable I2C
    The I2C interface is disabled by default so you need to enable it. You can do this within the raspi-config tool on the command line by running :
    sudo raspi-config
    For additional details on this step please see here.
    After you've enabled I2C you will need to shutdown with:
    sudo shutdown -h now
    With the I2C libraries installed I used the i2cdetect command to find the module on the I2C bus.
    i2cdetect -y 1
    and I got the following result :
    cd Adafruit_Python_SSD1306
    sudo python3 setup.py install
    Example Python Scripts
    Now we are ready to test some examples scripts. Navigate into the “examples” directory :
    cd examples
    In there you should find a number of example scripts such as :
    animate.py buttons.py image.py shapes.py stats.py
    These examples can be run using :
    python3  shapes.py
    The examples should give you screens that appear in the examples below :
    By modifying these scripts you can create your own graphics with shapes, images and text depending on your project.
View all instructions
