WiFi constant current led driver
Up to 48v | 5x3.5A, WEB UI ESP32 LED Driver
Public Chat
This driver is designed to control embedded LEDs (COB), such as CITIZEN CLU, CREE CXA, NICHIA NFCWJ108B and others, with direct voltage up to 36-45 volts.
The version has 5 independent channels 20KHz pwm,
FAN control and external NTC sensor.
Features:
1. Battery-powered real-time clock.
2. More powerful processor with WiFi and Bluetooth support.
The dimming frequency is increased by 20 kHz with 11 bits of steps and can be increased to 40 - 60kHz by reducing the bit step.
3. Output for connecting a 12-volt fan with automatic control.
4. Port with 3 GPIO for the ability to connect external buttons or peripherals.
Firmware Features:
- VUE JS Web interface
- OTA Firmware update
- Smooth change in brightness by points (for aquarium lighting)
- Fan PID control
- MQTT integration
- Synchronization between devices on the same network
View project log
