DMX Controller Mk2
This DMX controller to made to control stage/party lights through the DMX signal. This DMX signal is widely used for stage lighting systems
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
https://tinkersprojects.com/project/dmx-controller-mk2/
This DMX controller to made to control stage/party lights through the DMX signal. This DMX signal is widely used for stage lighting systems at festival and clubs.
This is the second DMX controller that I have made but works differently from the first. The First controller, 8 address in a row are selected that can be changed. 1 byte can be changed per fader. Most values in the bit steam don't need to change but some do. This new controller, each byte gets set either as a set value or to a variable resistor. Each variable resistor can change multiple bytes in the DMX bit steam.
This controller also has WiFi ready for wireless DMX in a different project.
specifications:
16×2 LCD screen
7 programmable buttons
2 selection button
8 variable resistors
XLR D
