Hardware redesign
A project log for Open Thermal Camera
Opensource, inexpensive, mobile thermal camera for use in electronics, home inspection, non-contact thermometer, heat distribution and more.
themarpeTheMarpe 09/14/2019 at 18:572 Comments
Open Thermal Camera went through a slight redesign. The hardware is now unified for both Type-C and MicroUSB version. The housing can accept either of the PCB variants.
(Right: Type-C variant, Left: back view of MicroUSB variant)
With this step the hardware part is coming to an end and we'll start with improving the application side even further.
[deleted]
TheMarpe wrote 03/07/2020 at 11:26 point
Hi Nathan, as of now the case isn't open sourced.
Will soon be available for purchase, so don't miss out!
Regards, Martin
xbst wrote 10/20/2019 at 02:11 point
Can you provide schematics for hardware design?
