Got Auto-loader Electronics Installed
A project log for Anti Drone Gun Turret
Armed with a Nerf blaster. This turret tracks and shoots down micro drones, otherwise know as "Tiny Whoops"
drew-pilcherDrew Pilcher 05/27/2019 at 02:020 Comments
With the auto-loader tested, all that was left to do was install the extra electronics in the control box.
I took the whole thing apart, drilled and tapped new holes, then re-assembled everything and re-routed the wires. Came out decently clean, despite being hacked in as an afterthought.
The system is pretty simple.
I used an M12 cable and some heat-shrink butt splice connectors to connect the nerf gun to the control box. These connectors are great, they're waterproof, and the can be installed with just a lighter!
