PxMatrix vs Adafruit RGBMatrixPanel
A project log for Drive RGB LED Video Wall Matrix with Only 3 GPIO
Using a few 74xx ICs, an ESP8266 can drive a video wall panel while keeping I2C and data pins free for use with Wemos shields
bornachbornach 05/12/2019 at 12:450 Comments
I've been reading the PxMatrix library source code. It doesn't seem to be using any bit plane based display algorithm. If I've read the code correctly, the ESP8266 makes 8 SPI transfer of pixel row data to create the illusions of a palette of 512 colours. Whereas the Adafruit RGBMatrix library shifts in 4 bit planes at differently spaced intervals to give the illusion of 4096 colours.
I think if the ESP8266 can instead use a bitplane technique, the number of SPI transfers can be cut in half and free up microcontroller compute time to do other things like respond to WiFi, run a simple physics simulation, or process user inputs in a game.
