Getting started with the PI
A project log for Astromech: R8-J4
When I was too lazy to build two robots, I've put them together
davedarkodavedarko 05/13/2019 at 11:040 Comments
Setting up a headless Raspberry PI A+ first.
  1. Download image https://www.raspberrypi.org/downloads/
  2. add blank ssh file to boot folder
  3. add wpa_supplicant.conf to boot folder https://desertbot.io/blog/headless-raspberry-pi-3-bplus-ssh-wifi-setup
  4. disable WiFi power management when using Edimax USB edit /etc/modprobe.d/8192cu.conf and add line: options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
